[SOLD] 360 LA V8 rebuilt engine for sale runs great
femtnmax
Dillon, MT
Over the last half dozen years I have slowly put the Challenger back together. I installed a nice 360 V8 engine. The engine runs great.
I am getting older than I ever expected to live, and have decided to put a big block in the Chally, so the small block has to go.
I could make a youtube video of the running engine, could have a local machine shop do a leak down test on the engine, or any other steps to help sell it.
I have over $5800 in the engine.
The engine is in Bozeman MT. I could meet you half way, or.....
I am asking $2200 OBO.
Please PM me on this forum.
The ad for the engine:
3500 miles on engine, runs great
Asking $2200 OBO
Parts list top to bottom:
Edelbrock Performer RPM intake manifold #7176 $260
Engine Quest magnum cylinder heads, 62cc closed combustion chambers $1600
10:1 compression ratio
2.02/1.60 Scorpion stainless steel intake/exhaust valves
Comp Cam beehive valve springs
Comp Cam rocker arm studs #4504-16, ARP polylocks #300-8241
Comp Cam 1.6 ratio adjustable rocker arms with roller tips #1416-16 $170
Comp Cam pushrods $100
Felpro gasket set with Q1008 head gaskets $100
Mopar LA 360 engine block bored .030 over $200
Ross flat top forged pistons with full floating wrist pins #99627 $600
Piston top .004 below deck, piston to cylinder head quench clearance .043 inch
Sealed Power moly piston rings $60
Eagle SIR forged steel connecting rods with ARP rod bolts #6123CB $280
Mopar cast iron crankshaft, external balanced with Mopar front damper $400
Standard sized tri-metal main and rod bearings $160
ARP crankshaft main bearing bolts #140-5001 $40
ARP cylinder head bolts #144-3602 $80
Comp Cam 260H hydraulic flat tappet camshaft #CL20-210-2 $190
260 seat duration, 212 duration at .05 lift, .470 valve lift, 1200-5500 rpm
Engine Pro double roller timing chain and gear set with 9 keyway adjustment $100
Mopar magnum timing chain guide set $40
Melling high volume oil pump, pickup tube, and drive #M72HV, 72-S2,IS-72 $170
Kevko 6 quart oil pan with internal baffles #M302, M301-1 $220
McLeod steel flywheel, external balance $350
Also included:
Machine shop work:
bore and zero deck block, lightly align hone main bearing bores, touch valve seats and lightly ream valve guides for correct clearance, install cam bearings, check and perfect connecting rod big/small end bore sizes $440
Engine mount brackets and rubber mounts
Mopar water pump and 180 degree thermostat
Proform HEI distributor & Moroso spark plug wires #67040 $300
2 distributor connections: 12 volt hot in and tachometer
Carter mechanical fuel pump
Alternator brackets
Crankshaft pulley and water pump pulley
TOTAL: $5860
Also for sale:
Dougs headers #D453, full length ceramic coated. Fits A,B, and E body with small block V8 engine: Dart, Duster, Charger, Road Runner, Challenger, Barracuda
3 inch collector, 1 5/8 primary tubes $620 MAKE OFFER
Crower camshaft 267/271 Mopar 340 cam custom repro, new in box $200 MAKE OFFER
Where were you about a month ago. I already bought a 360. Damn. That is probably a nice smooth running street engine with more than enough power. 350 horse??. Only change I would have made is a little more cam. Buy that's me. Bigger is better. LOL.
