360 La Vs 360 LA roller
nick.rembecki
Member
Buffalo, NY
I’ve been having trouble finding a LA 360 from the early 70s to swap into my 73 duster. I’ve found a couple LA 360 roller blocks from late 88-89. Is there any differences between the two besides roller cams and lifters? Should I continue to look for a early 70s 360 or would the rollers be fine to swap in?
Funny how that works. I have 2-360s from '73 and '76 and it's near impossible to find LA roller blocks in my area because everything is the older stuff. I would trade you one of my 70s engines for a similar condition roller engine if we were closer
Roller blocks are good, don't gotta worry about the cam going flat... And 88-89 is LA style so it oils the heads through the block not through the pushrods...
they're fairly close like for like, however there are some granular details.
the cam may or may not have a snout that allows for the mechanical fuel pump eccentric. not a big deal if you're running an electric pump already, and there's bolt on widget sold that will allow for a eccentric on the "short snout" cam.
to that note, roller cam selection is a little more limited and expensive. best to have your stock unit reground if you're looking for a performance grind.
on the exhaust the heads generally have smog ports on them for the air injection system. these are easily tapped and plugged.
i would totally go with a roller motor on a swap without a single hesitation.
I have an extra set of hooker headers that came with the car when I bought it. It currently has a 318 in it, would those headers bolt right up with no problem? I attached a photo of the roller heads, where would the smog ports be?
yeah, they'll bolt right up. *sometimes* you'll need to relieve the block or head a little bit for fit/clearance, nothing major.
those are aftermarket heads, they don't have smog ports.
stock they're under the exhaust port:
Buy them ALL. There's no practical difference.
I got a roller block and threw a solid flat tappet cam in it.
And an internal balance crank.
And forged pistons.
And new scat i-beams.
And a milodon timing gear set.
And promaxx cnc shocker 185's
Next up is coil near plugs.
I'd sell the hookers and get coated tti or dougs.
My 1990 360 also fits the roller cam/LA rocker shaft group.
The block itself has taller lifter bosses to better support the taller roller lifters but you can still use a standard flat tappet cam and lifter setup.
