360 magnum balance ? help before install
acpat
Mayetta Ks
I have a stock 2001 360 magnum motor. I have the proffesional products balancer that is only good supposedly for 97 and down motors according to them. I also have a Mcleod flywheel with the bolt on 360 magnum balance weight from brewers. I am wondering if I am missing something.
Mopar magnum engines book says harmonic balancer is same 93-2001
Mopar Magnum engines book says flywheel is same 93-2001
Balanced on both ends due to being cast crank.
Opinions welcome just getting paranoid the closer i get to making the valiant run
97 down = 2 piece damper(can add LA style v-belt pullley)
98+ = One piece pulley/damper (serpentine belt)
As far as I read,and seen.....so I might be off base.
Thank you DodgeAddict that is basically what I did and it all bolted up. just paranoid lol
