360 magnum flywheel
haybag
New Hampshire
Thinking about doing a magnum swap in my 69 Swinger 4spd. Found a 95 ram 3500 with a 360 5spd with low miles. Would this flywheel be compatible with my 833 trans ?
No the flywheel is too large in diameter for your bellhousing
Mopar made a 360 balanced 10 1/2" flywheel for the Magnum 5.9 engine not sure if it's available anymore
I may have one from a project that never took off if your interested I can look this weekend
Mopar performance or American powertrain for steel. Call me for aluminum
FYI, not sure what the OP's plan is, but if he wants to keep the SMPI, this flywheel wont work. If he is going to a carb, it's perfect.
There are options for the right sized flywheel that keeps the notches for the CPS, this just isn't one of them.
