360 manifolds/headers?
Ummmmmmmm, to general of a question this early morning for me. I have an idea though, click this ---> http://www.summitracing.com/
You can in put the year make and model of the car for parts your looking for.
the swap from /6 to V8 does not make any part available in cars with normaly available V8's un-useable.
In otherwords, what fit a V8 car will fit the /6 car with the V8 swaped into it.
Best headers is a topic well used around here. Best fitting would be ethier Dougs or tti's. While pricey, they do not have 3 out of 4 exhaust tubes going under the drivers front end linkages. Which result in dented/damaged exhaust tubes on the header.
go with the headers good upgrade and will help later with future mods get tti if you got the extra coin or get your self any header will be better then manifolds .
You want to order up a set of Doug's headers (mild up about 550hp) if your building 575+ you'll want to order a set of TTi headers (these leave room for future growth).
