360 mount problem
BWDart
New Braunfels TX
Does anyone have pics of 360 mounts in a 72 Dart?
I can't seem to get the mounts on so the single boss lines up and one mount I can only get two of the three bolts to line up.
One of my mounts has four holes the other has three.
Thanks
Bruce
The left side bracket/mount is your pass side.
The right 318 bracket/mount is your drivers side. It needs to be modified to work on a 340/360 block.
Both go behind the ears on block.
I used the 318 mounts on my 360 and all I had to do was make up a piece and welded it to my left bracket and drill the hole out and work great.
Thanks Cracked and Snake, that will solve the engine being too far forward also. I had them swapped left to right. I'll add that extension on the left side and call it good.
Thanks again
Bruce
Or do this
Thanks for the pics Cracked, a guy I work with is going to fab one up for me from the pics.
Thanks again
Bruce
