360 Oil pan
HemiPar
Kentucky
Need help. I am taking a 360/727 out of a 85 Ram truck and putting it into my 72 Swinger but not sure what oil pan i need. Do I need the center sump or what? Any help would be great thanks.
Jeff
You need a center sump pan for a 360. You also need the oil pump pickup tube to match the pan. I'm pretty sure you can use your old oil pump.
:burnout:
yeah you "can" use the stock oil pump over, but being that you have to remove it anyways and the cost what? like $25?? for a stock replacememt, doesnt it make sence to stick in a new one? I never do a swap like that without sticking in a new oil pump and timing chain. i doubt you will ever regret it
