[SOLD] 360 oil pan
rbkt65
jerseyville, illinois.
i have what is was told is a 360 car pan, with pickup. 50.00 plus actual shipping from 62052. will take paypal. will answer pm's in order received. also will answer any/all questions about pan. 1st pic is of rear pan lip. do your home work on lip measurement between 318/360.
360 pans take different end seals on the pan...
273/318/340 pans take the same end gaskets on the pan...
If the front and back of the pan are the same radius, then it's the 273/318/340 pan...
If the front and back of the pan are different radiuses, then it's a 360 pan....
demonracer and krazykuda, both you and i and most others here know how to tell but i was trying to avoid the not too knowing ones that do not know how to tell the difference.
