[WANTED] 360 small block motor mounts ASAP!!!
I have a set of 340 biscuit type mounts, $50.00. I am pretty sure they are the same. Maybe someone on the forum can confirm the interchange. PM for more information.
To make sure there is no misunderstandings, clarify if you need the block side halves, the mounts themselves or both.
this is the bisect type k member just checking
Do you need the B/E body or the A body? They are different. Brackets or rubbers? AutoZone has the rubber mounts for abou $5 each.
This is what the 340/360 A body looks like.Sorry, I do NOT have a set right now.
And this would be the 340/360 B/E mounts
