360 stainless steel roller rockers on ebay, too good to be true?!?!?
My Cat(chinkease,garbage). Had to grind everywhere. Finally, clearanced .Bro every where(Eddy heads). Broke a huge hydraulic in. The hardened pushrods,destroyed the garbage adjusters.
Thanks for all the advise, I had a feeling they were too good to be true, that's why i wanted to ask you guys first and I'm glad I did. A friend of mine said he'd sell me a set of Harland Sharps for $500 so I'll probably take him up on that.
Ya, I have a set of Cat 1.6 aluminum rollers on my 318. It's been a while ago, but I recall the spacers wouldn't work and the adjusters were utter crap. Wound up buying replacement parts from Harland Sharp. Think I had to grind a bit for retainer clearance. Only real worrisome thing I noticed was the lack of an oil feed to the valve tip. Wound up drilling a small passage through the existing one on the pushrod side. Never had an issue using them after a few thousand miles though. Ran these with a 340 resto cam and springs on shaved 360 heads/2.02 steel valves.
-James
