chrisd6875
Member
Hi all,
I just started my LA 360 on Friday to break the cam in and have a fairly loud knocking sound from the passenger side. I bought this engine a few years ago and replaced mostly everything except the pistons, rings and crank. I had the heads redone, and installed a Cam/Lifter kit.
I removed the valve cover on that side and found that some of the rockers are not tight. I'm not sure if they should always have tension on them? I do remember when I installed the rocker assembly on that side that some of the rocker were loose, especially one which has more than a 16th of play between the push rod and the rocker. They guy who guided me with the cam break-in, said that it might tighten up after the lifters fill up. I changed the oil after the break-in, and ran it again with no improvement.
After I took the cover off I removed the rocker assembly to see what was going on. I measured the push rods and the rocker and then noticed the valve stem tops were all a bit different, one is lower by a good 16th of an inch. Is this normal? A few more by about a 32nd. Could this be the source of the knocking? The push rods are original as is the rocker assembly. Rocker assemblies were torqued down properly, also had plenty of oil up on top of the rockers and springs. The heads are 360 heads, I supplied the springs they are comp cam 901-16. The cam/lifter kit is Lunati 10200701LK.
