dart360swinger
Boosted
I'm selling the powertrian set up out of my car. Motor, Turbo kit, and Transmission. On a chassis dyno the car made over 405 rear wheel horsepower and 510ft lbs of torque on only 8lbs of boost! come hear it run before I pull it out to make room for the Big Block Turbo to come.
-Motor-
1972 360ci 0.030"over
stock crank and rods reconditioned
Speed Pro hypereutectic pistons
"J" heads w/ 2.02 in 1.60 ex valves
Lunati VOODOO cam .474/.494" lift 268 advertised duration w/ matching valve springs
Edlebrock RPM airgap intake
750cfm Holley double pumper carb converted to blow through
-Transmission-
1971 727 w/ 2200 stall and shift kit
-Turbo-
Garrett GT32 variable geometry turbo
304 stainless shorty headers with 3/8 flanges
2 1/2" exhaust piping from headers to turbo
3" down pipe
3" aluminum intake tubing, all mandrel bent pipe
18" intercooler
38mm waste gate
38mm blow off valve
Spectre carb hat
all exhaust connections are v-band clamped for higher pressures
$4,000 Pick up only, no shipping. I may be willing to drive part way to help deliver.
Jake
Nampa Idaho 83686
-Motor-
-Transmission-
-Turbo-
3" down pipe
18" intercooler
38mm waste gate
38mm blow off valve
Spectre carb hat
Jake
Nampa Idaho 83686
