[WANTED] 360 windage tray/bolts/oil pan
I think I have an oil pan and I do have a windage tray. Could bring to moparty next week if interested. Let me know and I'll dig em out and send pics.
I have no issues in shipping just thought I could save you the shipping cost. I could ship from Bowling Green as it would be closer and possibly quicker. I'll dig out and post pics of what I got.
Thanks
Upon investigation I don't believe that it's a 360 pan but this is what I got.
Which ones the small tray bolts or the main bolts ?? I believe the main caps and main bolts are different between 340 and 360.
I thought the 340 bolts were slightly shorter ??
Seems to me that the 360 are slightly wider and taller but I'm not 100% sure. I do believe I have the main bolts with the provisions for the windage tray. I'll look tomorrow as I'm just about to go out the door for the evening.
Thanks
Thanks
340/360 bolts are the same length. The MP kits came with the longer 340/360 bolts and 8 hardened washers to be able to use the kit on 273/318 with using 2 washers per bolt. They also had the 4 little bolts with an encaptured washer. Kim
The bolts are what really seal the deal. Mancini sells a copy of the tray, but only offers main studs. I've always heard that installing studs requires a line bore, and I have no intention of tearing down my motor at this point.
New tray, with the slotted holes so you can use it on 273-318-340-360, and used original bolts. Original pan. Pm me if interested.
