383/727 Value
middleagecrisis
Seguin, TX
I bought a built 383 that I have heard/seen run. Engine had no smoke at cold startup, 80 lbs. (observed) of oil pressure and had a lot of cam lope at idle. The owner that built the engine doesn't have much documentation, but say's professionally ported HP iron heads, KB pistons (~10-1 Comp), custom ground Crane hydraulic cam. Observable things I can confirm: Edelbrock TM6 intake, Davinci 750 DP, old Mopar Electronic (MSD type) distributor and box, mini-starter, steel crank (Small balancer), adjustable factory rockers & a deep sump oil pan. Motor was built for the race car I'm selling in the classifieds. I also have a 727 Trans King (per owner) reverse manual valve body with a 9" converter (~3K stall) that I have video of going into forward and reverse gears. I bought all of this to put into my '75 Duster after looking for well over a year for an LA 360 and small block 727 trans. Of course, now after buying the 383/727, I found a builder 360/727 at give away prices. What's opinions on a realistic cost I could get for the 383 and the 727/with converter? Would it make a big enough difference in value to remove the heads and oil pan for pics and then to reassemble with new gaskets? I like the idea of idea of putting in the 383, but replacing the existing 318 with a built 360 would be much easier, and probably not a huge difference in power. Thoughts?
Not sure how much this will help you but it's tough out there right now. I've had a 440 hp core with fully forged internals for sale for a while now at what I thought was a giveaway price and I opened it up so that the whole thing could be inspected and all I have gotten is people offering scrap metal prices.
If you take it apart for pictures and then put it back together I guess it will only help your listing have a little more luck.
Not sure how much you paid for the 383/727 but maybe use that as your starting point for pricing to just break even. Maybe add $50-100 on top so that people can negotiate you down to that point. If it doesn't sell in a month or two then open it up, take the pictures, and close it back up again like you suggested here.
For what it is worth, during covid when the world was shut down, I almost went to go buy a "built" 383 (no proof or documentation but it looked freshly painted) for $600 so I assumed it would at least just be a core. It sold almost immediately and popped up a week later with someone else trying to sell it for $1,900 without doing anything to it and it's been online ever since
It appears that I couldn't build the 360 (Core) that I already have for the same cost to get it to the 383 horsepower level. Not to mention, I'd have to build a SB 727 to handle the 360. Looks like I'm going back to the 383/727 plan.
Leave it together. Serious buyers will bring a scope to look down the bores. If your building a 360 have it internally balanced . Then have the big block internals put in a small block case. And use the converter you have.
I'd say the 383 plan would be worth the work and frustration, and TTI under chassis low deck headers would be worth the money for the outcome.
I'll add that I believe that everyone wants a big block A body at one time or another. I'm all for making the best with what you have in this instance because the juice should be worth the squeeze if you're wanting a thrill ride.
i'd say carry on with the chonk block. you've got the big pieces so you're most of the way there, and the bonus is that it sounds as if it's a healthy unit with some choice bits and bobs to boot.
basically you'd be looking at figuring out cooling-- which you may already have covered, but if not you'd be spending the same dough with a small block. exhaust which again, if you don't already have headers for the 360 you're looking at basically the same coin for the B units. and then splash the cash for some swap mounts, which isn't a ton of cheddar.
that's what? 2500 kubel koins? give or take to get that shoehorned in. ain't no way you're getting a small block rebuilt and installed for that kinda bread unless it's stone stock and you're got most all the high dollar parts to start.
edit: B for the low deck 383, not RB for them tall blocks
Exactly! Except he'll need the B and not RB headers. That B engine has a little extra room than the RB in an A Body as well for rocker cover clearance as well.
derp. thanks for bringing it to my attention. editeded
100% on the low deck motor having more space, it's about on par with a small block with headers to be honest.
