383 cam I. D.
derek fletcher
Active Member
paso robles,ca
hello,
I purchased this big block with my 67 Dart
Now it's time to deal with valve train.
Pulled cam and came up with these numbers.
Crane F284 H3102 B151
Can't seem to find it in catalog.
any help would be appreciated.
Thanks Derek
Google is your friend…….
From Cranes Chase Knight himself:
Greetings, this is an F-284 mechanical (solid) lifter Crane camshaft from the late 1960's. It's a single pattern camshaft with 284 degrees advertised duration, and 241 degrees duration at .050" tappet lift. Lobe lift is .302", gross valve lift with 1.5:1 rocker arms is .453". Lobe separation is 112.5 degrees. Recommended valve lash at operating temperature is .028" intake, .032" exhaust. This should have a fair idle, with a basic rated RPM range from 2600 to 6000 RPM. Regards, Chase
