383 into a 72 Demon
Big Block A body Tech
  1. y2bee
    y2bee Well-Known Member
    57
    0
    Nov 27, 2010
    Millerstown Pa.
    Local Time:
    11:27 PM
    I am wondering what number oil pan I would need to put a 383 in my 72 Demon.Any other sugestions would also be welcomed.
  2. 67valiant 100
    67valiant 100 go fast or go home
    1,663
    30
    May 3, 2010
    Orange County NY
    Local Time:
    11:27 PM
    You need a 187 oil pan. They came in late '60s early '70s big block C-body's.
  3. y2bee
    57
    0
    Nov 27, 2010
    Millerstown Pa.
    Local Time:
    11:27 PM
    Thanks for the info.Checked out your Valiant build-will be nice.
  4. 67valiant 100
    1,663
    30
    May 3, 2010
    Orange County NY
    Local Time:
    11:27 PM
    Thanks!
  5. mopar7172
    mopar7172 Banned
    550
    2
    May 20, 2009
    las vegas,nv
    Local Time:
    10:27 PM
    or a #699 oil pan.there the same as the #187 pan
  6. demon seed
    demon seed The Original Demon Seed
    6,438
    46
    Jan 6, 2006
    South Alberta, Can.
    Local Time:
    9:27 PM
  7. 68dodge
    68dodge Well-Known Member
    1,434
    297
    Jan 23, 2008
    Armagh, Pa.
    Local Time:
    11:27 PM
    I would recommend fitting it before you paint it. On some cars you will have to trim or tent the pan for idle arm clearance on the outer edge of the arm. I have seen this were you never had to to do anything to the pan. It could be the way the pan is stamped out when made.
  8. 74fldart
    74fldart Well-Known Member
    213
    0
    Apr 13, 2008
    orlando, florida
    Local Time:
    11:27 PM
    something you might want to do is weld in a baffle on the back side of the sump to control oil slosh on acceleration.
    here is a factory type:
