[FOR SALE] 383 Rotating Assembly
540dust
Indiana
Rating - 0%
0   0   0
.030" over 383 rotating assembly complete, balanced, about 7 passes less than 50 miles, includes all rings, pins (Diamond), spiro-locks, pistons (Diamond 51900), rods (eagle CRS-6358-C3D), Clevite main and rod bearings .010 undersized. Good race quality set, price reduced $850. Buyer pays ride. Going stroker, nothing wrong with this assembly.
so theses are 8 to 1 compression?
Big Block Chrysler Street/Strip forged Diamond Pistons are designed to fit most Mopar OEM open and closed chamber heads. Can be used with small nitrous application kits. Ratios are configured for .009" -.025" deck height @ 9.980". Standard 1/16" x 1/16" x 3/16" ring package (Rings not Included). Premium 8620 wrist pins are included. Gasket volume= 9.9cc, Top ring down from piston crown .240", Max valve diameter 2.140" intake and 1.850" exhaust valves. Valve relief depths .197" intake and .163" exhaust.
Compression Ratio with 72cc Heads 9.8:1
Compression Ratio with 80cc Heads 9.1:1
Advertised piston weight 630 grams.
