[FOR SALE] 4:56 gears & R3 motor & 727 parts
1badazdart
Holiday Florida
Got a oil pan oil pump and pickup R3
727 Hemi drum
Roller cam vale springs
4:56 ring gear and piñon
$400 oil pan
$50 Hemi drum
4:56 gears $50
Roller vale springs $150
+++ shipping
Ring and pinion to what case?
Prices on everybody?
I got the gears in a bunch of parts but I don’t know what case it’s for
Look on the side of the ring gear and see what it says. It should have the tooth count and the part number for the ring gear on there and the manufacturer's stamp. Is in an 8 and 3/4 ring gear or is it a 9 3/4 ring gear or is it a 9 1/4 inch ring gear?
Either way it's either going to be a 742 pinion or Dana or 9 1/4 pinion.
If the price is right I'm interested.
Okay the Price Is Right on the gears we just need to know what they're for. Measure the ring gear and see if it is an 8 3/4, 9 1/4 or 9 3/4 inches.
Will check on that today after work
What is the pan for a 318 340 or for a 360 or Magnum?
I am a big block guy I know there’s a difference in the oil pan from a 340 to 360 but don’t know if there’s a difference in the R3 pan if I can get the measurement across the front or the back opening where Rubber seal goes
I'll give you $25 an shipping for the 456s. Seeing as you don't know what they fit and I'm willing to take the chance on figuring it out.
