SonofaHatchet
Has anyone tried swapping in a newer 4.7? I was driving home today thinking about it, I think it would be pretty cool. So let the commets flow8-) Thanks
I wouldn't touch a 4.7. I have seen more issues (early versions 2000-2003) with more rod/ crank issues than you can shake a stick at. That being said, trying to find a used one is fairly expensive too.
have a 4.7 in my 2000 jeep grand cherokee limited....love it,runs great at 106,000 miles on the clock.
much smoother acelleration than that of a 360 I have got as good at 26 MPG on the highway and 21 city....on average is more like 16 city and 21 highway.
but like others have said.....finding aftermarket swap parts would be few and far between and you would have better luck swapping a new hemi or a magnum 360 or something that parts are more available for.
They are prone to sludge because the factory runs the cylinder head temp higher for emissions. You see when they design an engine they need to make it for at least 10 years to recoup the cost of development. So they run the cylinder head temp up so it will be able to meet emissions at least 10 years down the road.
Having said that if you change the oil religously at 3K miles and/or use synthetic oil you'll be fine but otherwise there isn't much incentive to swap this engine into anything it didn't already come in. No aftermarket support, small cubic inches, you'll have to convert to the fuel injection, it's just a mess and not worth the hassle. Swap a Hemi in though and that is well worth it. Plenty of aftermarket support, you can run a carb or injection and there are plenty of aftermarket electronics available for retrofit.
Wouldn't changing the thermostat to a 180 help with the baking of oil in the heads? Or would that throw "out of whack" all the temp controlled electronics..
If you put a colder stat in the computer will tend to run it richer, it thinks it's cold so although performance may be up just a tad fuel mileage will be down. Cylinder head temp is not just dependent on coolant temp. Think combustion chamber temperature. So not much help there.
