[FOR SALE] 4-barrel dual opening air cleaner $50, carb insulator/spacer.
smokinnjokin
Nekoosa, WI
Off my 360, a great driver condition 4-barrel air cleaner. ***SOLD****
Unknown original year/model, it has the 2 openings but no snorkels attached. Black wrinkle is in good shape, has some rub marks from pie pan and small dings but nothing really noticeable. Includes carb stud, wingnut and clean air filter. 5.1" diameter opening fit my edelbrock carb perfect.
$50 plus shipping. * SOLD***
Edelbrock 8724 carb spacer with studs and gaskets, .5" wood (insulator) for square bore carbs. Gaskets have been very carefully cut so that the excess from the spread bore inner holes are not overhanging. Mounted once and removed because hood wouldn't clear. They help big time with hot starts, keeps carb much cooler so fuel doesn't boil off.
Spacer has also had the outside edge painted (again, very clean looking) with high-temp black so that the wood color is not noticeable. They are $30 on Summit. Edelbrock Carburetor Spacers 8724
$20 SHIPPED via USPS priority.
Thanks for looking, cross posted on FBBO.
View attachment 1715410068 View attachment 1715410069 View attachment 1715410070 View attachment 1715410071
$50 plus shipping.
Pm sent on air cleaner
For everyone's info, yes the snorkels were removed by a previous owner. They were not hacked off, snorkels actually fit over the protruding portions that you can see in the picture and are secured with 4 tack welds on each. The welds were probably broken with a mallet, and then the snorkels pop right off. No cutting required. Why the hell they did that, I have no clue. I now have a mancini low-pro air cleaner.
