[SOLD] 4 sp pedals SOLD and 8.75 lower shock mounts
twister6adh
Mountain Home, AR
Rating - 0%
0   0   0
73-76 Pedals sand blasted, clear coated and painted. Includes spring, brake light switch and clutch interlock switch. New bushings bump stop and pedal pads from Brewers. Shipped to lower 48 $400 SOLD
Lower shock plates for 8.75 rear. Blasted and primed. Shipped to lower 48. $100
Paypal Shipping included in price From 72653
Sorry for the question but what is the difference in the 73-76 pedals? I jave a 72 I am going to convert from automatic to manual and if these would work i.wpuld be interested.
So 67-72 the pedal rubber pads are smaller. Starting in 73 they are larger and they added a clutch interlock switch (small round thing with wire coming from it) which keeps you from starting engine unless clutch is pushed in. Will they bolt in? Yes. Will a purest point it out? Yes.
Ok I thought the framing looked the same. Actually the larger pedal might help as I have a size 13 foot. So I suppose the clutch interlock switch could be easily taken off or just not hooked up? Those are some nice looking pedals and I am very interested
Yes, your 72 probably has no provision in the harness to hook up the switch anyway.
