I searched the this forum looking for info, found some, but not specific to my questions.....Ok I thought I would take apart my 4spd pedal setup, sandblast and put new bushings etc in it. I put the setup in my vise and pushed on the clutch pedal, well it took a bit, but I was able to push it in and it "snapped" in to place and the spring literally fell out. Ok luck is on my side I guess...I figured I would have to do the washer trick with it, but I didnt have to. So I moved onto trying to get the clutch pedal off. But it looks like a washer was welded on?? Should I grind the washer off or leave as is and just be careful sandblasting?? Also where can I get a bushing kit for it?? I checked Brewers performance out but didnt see a kit. 1st 2 pics are brake pedal side, washer looks welded instead of "C" clip. Last 2 pics are the clutch pedal side.
Thanks for help
Thanks for help
