ssba
I have for sale is a nice Hurst offset chrome stick and console for a 68.
I put this assembly together for a barracuda project that I doubt I will finish.
The handle is NOS or restored. Not really sure which but it looks new. Woodgrain ball is new.
The console body started out as a great condition black auto console without any cracks. It has a rub or wear mark (pictured) on the forward nose that cant be seen when installed. I think it must have been rubbing on the AC parts during use? Then was cut for the side hump patterned off a original stick console that was damaged.
I then added new repo top plates and a NOS boot.
The side hump is a repo fiberglass part. New carpet kit also.
The top plate kit came with a new ashtray lid but not the under lid parts so they show their age.
Ashtry has some rust in the bottom and some pitting in the chrome on the reused tray parts.(also pictured) The boot is just dusty and will clean up like new.
Console mounting brackets are still welded to floor but will cut out and include if needed.
I will sell for what I have in these parts alone. 1400.00 + shipping.
This was not a quick and easily done putting this together. It can save you the time & problems
I had assembling this set.
The handle is pictured mounted to a passion aluminum case 18 spline that can be made available with the console parts along with all other needed parts for a 4-speed conversion if that's what you need. PM replies is likely best for me. Can send more details or pictures thru email if needed.
