[SOLD] 4-Speed Conversion Package
69GT
Metro Detroit
I collected all of these parts to convert my 69 Dart to a 4-speed but have decided to leave it an automatic. Nearly everything you need to convert your car to a 4-speed is here. You may need a few bolts or some other small item but I think I covered most everything when I was buying this stuff to convert my car. I am not selling any of these parts separately, only as a package. I am asking $2400 obo for everything. I would prefer not to ship so local pick-up (Detroit area) only.
69 Dart 4-speed floor hump
69 Dart clutch pedals (heavy duty type with the spring guard)
69 340 Bellhousing #2892482 including trans. bolts
Flywheel
Clutch fork
Bell housing dust cover (starter seal)
New small block bell housing inspection cover 2843892
10 1/2" used 1506 Borg and Beck pressure plate
New clutch disk
New throw out bearing
Shifter rod set with nuts and clips
New clutch fork boot
New clutch rod firewall boot
New Z-bar bushings
New pilot bushing
New small block bell housing ball pivot bracket
New A-body small block clutch adjusting rod kit
Z-bar
2 plastic washers and end seal for z-bar
Z-bar ball stud frame bracket
Z-bar frame ball stud
Clutch pedal to z-bar rod
Factory A-body shifter handle
Shifter boot and trim ring with screws
Shifter box to transmission mounting plate with correct bolts
69 A-body 4-speed transmission
Hurst Competition Plus shifter box
New in unopened box black A-body 4-speed carpet
Reverse light for dashboard
