4 speed flywheel, clutch, scattershield, shroud, shaft
GermzD74
Cool Member
San Diego, CA
Rating - 0%
0   0   0
Looking for a flywheel and clutch kit for a 340 with forged crank (internally/neutral balanced), if anyone has a set new or used laying around...if used, I can turn flywheel but clutch kit needs to have a good amount of life left.
Also looking for a used scattershield with plate.
Drive shaft for A 833 to 8 3/4
Fan shroud
Thanks!
have a 50 lb brand new hays flywheel if interested or a used hays setup noscattershield
Cast or forged crank? Do you know if it's internal or external balance?
