[SOLD] 4 Speed Pedal Assy.
DustyEd
Far Out, USA
XXXXXXX
Do not need, so selling an A-Body clutch/brake pedal assembly, complete with harness bracket, brake light switch, and neutral safety switch with pigtail. Not sure of the year. There is #1704 stamped on the brake pedal arm, if that helps. If you know the application, please educate me. $300 shipped in the U.S. from central IA. Payment through Paypal (to a friend, please). Thank you.
One source identified this clutch assy. as follows:
"Technically correct for a 1968, 1969 Barracuda, Cuda, Formula S, Dart GTS, 340, 383, or Swinger 340, but can also be used for other applications where a factory supported bracket is desired on a 1967 or later models 1970, 1971, 1972 Valiant, Duster, Twister, Scamp, Dart, Demon, Sizzler, or Swinger with manual transmission. This is a factory heavy duty 4-speed bracket used with 340 and 383 A-body applications."
At this time, I have no way of knowing if the above information is correct or not. However, the fellow I got this from was going to put it in his '71 Dart.
Really thought this was a fair price at $300 compared to others in the $4-500 range. I want to get it to someone that will put it to use, rather than sitting in my shop taking up space. So, I'm willing to take best reasonable offer. Thank you.
this is actually a 70 and up pedal assembly. it has the clutch with on it. makes even more desirable. its a great deal with the switch included
