4-Speed Swap Neutral Safety Switch Problems
vocals
Vancouver
Hey All,
I just swapped my 69 dart and now I have the 3 prong plug from my 904 thqt is not correct for my newly installed A-833. I'm pretty sure the middle prong is the NSS and the L & R are the reverse switches. How to I wire that to the 2 prong plug on my tranny??
Thanks for any help!
Hey All,
The is the 2 prong I'm talking about.
Hey All,
Connect the wires that lead to the outer terminals of the 904 three prong connector to the A833 reverse switch terminals using 1/4" female spade terminals. The order of connection does not matter.
To use the wire that leads to the center terminal of the 904 three prong connector, connect to a ground if retaining the automatic style starter relay where the other end connects (G) or to the clutch pedal safety switch if using one. If using a 1969 and earlier style starter relay that already has the grounded terminal, leave the center terminal wire of the 904 three prong connector unconnected.
Thanks for the info! A buddy of mine who is a mechanic told me the exact same thing 20 minutes ago and it worked perfect.
