4 speed trans swap question?
mopwr2004a
low slung chassis
LaPorte, Tx
will a slant 6 bellhousing work for a big block 4spd trans. the trans is going behind a small block
...........it may fit the slant bell, providing it has dual bolt patterns........a slant bell wont fit a sb.............kim.........
yeah after I posted I realized what I had asked. its a small block bellhousing for a 3spd. and he wants the big block 4spd trans I have to put in his a-body will it fit
What is the trans out of and what year is the trans ? 18 spline or 23 spline ? the bearing retainer may be the wrong size depending on the year of the trans but that can be worked around .
Does his bellhousing have both 3 and 4 speed patterns ? If not he is going to need to get another bellhousing.
I know nothing about it's history. how can you identify it. i have measurments of the bearing retainer, and casting numbers I think it's 18 spline I wld have to ck
