4" stroke crank in florida
Dart_br
Active Member
Brazil
I'm not sure if here is the right place to post this, but i need a help.
I bought a cast 4" stroke crank from summit, but they can send it to me only feb 25, and i am not from the US, i'm in Forida for vacations, will stay here only until feb 22. I want to know if there is a shop in Florida were i can find those kind of parts, i also need a intake manifold, bearings, etc, but the crankshaft is the most important part that i came to buy, if someone know a place in florida or even South Carolina, please, let me know as soon as possible!!
Thanks a lot!
just google speed shops in the area your in you might find something good luck.
Check with Dan at Performance Only. I believe he's in the Palm Beach/Del Ray Beach area
try mancini racing they keep a good inventory and you should be able to get it next day air. it will be exspensive just a thought.
Thans very very much for the replies, i will try all this options, and i'm sure that i,will not go back to Brazil without that crank.
