[SOLD] 402 Small Block Stroker - INDY RHS HEADS - 6 PACK- NEW
68GTconvert
Mill Valley, Ca
402 Small Block Stroker Motor - INDY RHS HEADS - 6 PACK- NEW Complete
Short Block is COMPLETE put together by MADDART and Brian at IMM(best mopar engine builder on the west coast)
Machined, bored, line honed, gear drive, new oil pump, pan, pickup, has windage tray. Scat 4.0 Cast Crank, eagle esp rods with arp, ICON 745 FORGED Pistons, Moly Rings. Clevite Bearings. SFI DAMPER & WATER PUMP INCLUDED! Hughes "Johnson Race Lifters.
Hughes Hydraulic Flat Tappet.
With Brand New RHS Indy Heads 63cc put together by Brian at IMM compression will be 9.9:1. He pocket ports these and cleans up the bowls. Beehive valve springs. They are sweet with new ARP bolts.
New Felpro SBM Gasket kit.
Brand new six pack carbs in the boxes, new six pack intake, new six pack air cleaner and filter and new six pack install kit with all fuel lines etc. With 340 Six Pack Sticker.
New recurved 4secondsflat mopar distributor.
New Speed Pro(older hughes) Roller Rockers with correct length Comp Cams Pushrods. Brand new Fluted Hardened Shafts and hold downs from Hughes.
Front aluminum accessories with power steering pump etc for A Body Dart.
New HEI Set up for Mopar.
This Motor should produce 500+HP and 520 Torque. It is all Brand new and I didn't assemble b/c I want you to be able to inspect it. I am moving on from my project and trying to get a Hellcat.
The block is a 318 TRUCK BLOCK that has 4 ears on it for motor mounts instead of 3, HD for the Day I guess and was offset bored to an off the shelf 360 stroker piston by Brian at IMM ENGINES. Brian did all the machine work and balancing on this engine and MadDart assembled it. The block was magged before any machine work was done and it checked out fine. Main clearances are .002 and the rods are .003, crank end play is .006 the rings are gapped at .026. You can smack it with some nitrous it is ready for it!
$6750 firm.
I won't ship. I would like to sell as a package but I will now separate things but I am not shipping the short block or the heads so PM me if you are interested.
