[SOLD] 408 ci R3 engine
Mgc340
Sioux Falls, South Dakota
Mopar R3 non Siemese block 044796
9.569 deck height
360 mains 59’
Mopar 4 inch forged crank
H-beam 6.123 Eagle rods ARP2000
Custom Ross #76772 pistons for boost
Bore is 4.030
Compression ratio 8.79
Cometic head gaskets
Hydraulic roller cam by Cam Motion
Gross lift .539/.527
Custom aluminum 8.5 qt Oil pan with windage tray built in. Return lines for supercharger or turbo.
Mopar Sfi damper
Top end:
Magnum R/T heads
Flow 283 cfm at .700
Crane 1.60 rockers
Mopar single plane intake
Fuel injection with throttle body
F.A.S.T sequential engine management system
Msd box, coil, and controller for boost
Fast wiring harness
Oil lines and cooling lines
Shorty headers
Dual fan aluminum radiator
This came out of a 2000 Dodge Durango believe it or not. No money was spared. This has less then 1000 miles on it. It had a Paxton supercharger on it, I don’t have the blower sorry. I will sell this two ways. Everything I have for this which includes motor, wiring, electronics, radiator, and headers for $8,500.
I will also sell the top end magnum stuff:
Heads and rockers, intake and fuel injection, electronics, all the wiring, radiator, headers, magnum water pump for $2,500
I will also sell just her short block with oil pan, and timing cover, damper. For $6,000. That included a R3 block fully machined. Forged rotating assembly. Custom oil pan.
I can ship through Fastenal on a pallet for $150-200.
