408, Small or Big Block? Need EGT Info
EGT 12.5 ish 15 spike
I researched this as I will be running nitrous which can quickly spike egt
Keep a close eye on timing
Brooks, that would be AFR (Air Fuel Ratio), not EGT (Exhaust Gas Temperature).
To the OP, like have others said, you are better off looking a AFR than EGT for tuning. Tune it with the AFR and you won't have to worry about the EGT.
And a total side note, if you If you don't get on the motor soon its going to be a pooch ("have not taken it above 3000 RPM")....just sayin....There have been studies of identical engines that are broke in and babied v.s. the "hammer down" approach, and the latter make more HP. All of my engines I do the hammer down approach, and they run quite well.
And yet another side note: My AFR's with e85 look so very difference than gas...I run mine at 0.77 lambda at WOT.
