go tto their website and look at the "A" measurement. that is what you need to consider on the steering side of your hotrod. if that clears the steering you're in.
as a side note the steering shaft can be moved over to the left something around an inch. you need to loosen the 4 bolts holding it to the fire wall and elongulate the holes. you won't notice it when in the drivers seat and if you do you will get used to it. i moved mine over to the right for clearance toget the 2 3/8" pipes in. look where the shaft comes thru the firewall.
