Why would you want bigger pushrods in an otherwise stock hemi? The usual answer is cause the old ones bent. If so the problem needs correcting not a band-aid fix. Back to point,cause of the valvetrain geometry odds are they will rub. And you would need to check every one throughout the complete cycle. Personally I think its a bad move. Heavier pushrods? Nahh! Stock motor,,,,,,
