To start off with thanks everybody for answering all the transmission questions lately. The background of this is a building my barracuda Gasser currently. The main reason I’m building the car is eventually to take on drag week. I was originally going to put a four speed in my car and then I started thinking that driving it on the highway would probably be absolutely miserable for hours at a time. In reality if I actually wanna do this drag week thing I really should consider a transmission with overdrive. I had considered an AX 15 transmission, which is a five speed that was found in Dakotas, but members on here have said that it won’t hold up to drag racing. I need to build this car on a budget and I am pretty innovative and determined. I don’t care about cutting transmission, tunnels, or fabrication work. I can do all that. I have been reading and reading and reading about the 42RH transmissions. Essentially they were the 904 based for speed transmissions found in Dakota is and llight duty trucks. It appears that in the very early 90s they made non-lockup versions of these transmissions. I believe some of the 46RH transmissions were also non-lock up. Please correct me if I’m wrong on any of this. My question is on these transmissions how well would they do with racing? For the non-lock up versions do the 904 and 727 converters work in them.? Are manual valve bodies readily available for them and overall is this a fairly budget oriented option if I rebuild a transmission myself. I’ve looked at how people actuate the fourth gear and to be honest I would be fine with just flipping a switch on the dashboard rather than running the pressure switch like a lot of people do. I really just need that fourth gear for that highway, cruising from track the track. Also if I were to race the 42RH what kind of internal upgrades do I need to do to make this thing hold up?
