So I'm (hopefully) picking up a 440/6 next weekend. Assuming all goes well there, I'll be dropping that big pig in an A-body Swinger. (70-72)
Ideally I'd like to put a 4-speed in it, not really concerned with overdrive, however I want something that will hold up to some abuse.
Doing a lot of research, I'm reading a lot of conflicting info, the majority of it appears to be combinations that "should" work, I.E. advice from people that have not actually done it. Other than that mostly either A-body or B-Body specific combinations.
I'd like to avoid the 727, they are a dime a dozen sure, and I'd go that route as a last resort.
So....18 or 23 spline....from what I have read, both will work? (23's seem to be a dime a dozen)
Bell housings: TOTALLY lost here. No idea what size(s) I need, 10.5, 11, A body, B body, IBR hole(5.125" or 4.35" or 4.80")
And lastly, tailshafts. Not a clue here. I have no isues getting a custom made drive shaft, but as far as what is going to fit/work under an A-body....clueless.
I appreciate the help in advance fellas. I know I'm biting off a lot, and I'm green as hell. But I'd rather learn and do it the right way, than screw it up and do it 10x guessing.
If I'm missing anything else, let me know. I know it's going to take a lot to get this done right.
