440 4x4 puller engine
dstdevl
bruce t johnson
Wadena Minnesota
What do you guys think? I want to build a 440 mopar engine to be used in a puller truck. Will not see the street,limit of 480ci so that eliminates 4.15 stroker kit. 1000cfm limit on carb.Trying to keep budget around 7,000 parts and labor. Truck dry weight around 6200lbs. Pulling skid weight 275-300 ft. Launch rpm of 4500-500 trap rpm 6500-7000 rpm. Any one have some good ideas or things to be avoided. Thanks alot, BT
