Hyper Henry
512 ci (4.25 stroke 4.375 bore, 1977 block)
H-beam rods (790 grams) 2.200 journals with ARP 2000 rod bolts
Diamond Pistons .990 pins (612 grams) approx. 12.3 comp. with 84 cc heads
Clevite 'V' series coated main and rod bearings
ARP main studs
Hughes main girdle
Milodon 31150 8 qt, pan with built in windage tray, crank scaper and trap door
Milodon 21110 single line swinging pickup with remote filter adapter and adjustable pressure regulator
Melling HV oil pump
440 based 512 c.i, stroker just back from the machine shop and completely gone over and freshened including new bearings installed. This motor will make an easy 800 hp plus with a good set of heads and the right cam and still be able to run on pump gas. $3950.00 cdn. Very little room for negotiations if any at all!!
Prefer pickup but I can ship if needed.
I also have a complete Comp Cams roller setup for sale:
Comp Cams roller lifters #829-16
Comp Cams solid roller cam #23-000-9 (.693/.660 lift, 274/280 dur. @ .050 108 LS)
Comp Cams roller springs #943-16
Milodon bronze gear #21523
Billet 9-way adjustable timing chain
some new and some in excellent used condition $950. for the package
Located in Kitchener, Ontario , Canada
ARP main studs
Hughes main girdle
Melling HV oil pump
