Hi, new here from the UK.
I’ve had a good strong running 440 for the last few years. Engine was stock other than edelbrock torker intake and Holley 750cfm vac sec carb. Ran great, plenty of power, nice and responsive.
I was recently generously given a 6 pack carb setup, believed to be original, on an edelbrock aluminium intake.
I have stripped the carbs, ultrasonic cleaned them and rebuilt, new gaskets, vacuum lines, intake manifold gaskets etc. I cannot find any vacuum leaks.
At the same time I installed a new pertronix billet distributor and flame thrower 2 coil.
Issues I’m having are:
With the transfer slot set to a square, the car idles far too low, and the idle mix screws don’t appear to have all too much of an effect on anything, however are set to 1.5 turns out currently. I’ve set the timing at 18 degrees as this is where it appears to be seeing about the most vacuum at idle.
With the idle as low as it is, the transmission will not go into gear without the engine stalling. Transmission is a stock 727 with a transgo TF2 shift kit. Has always worked great.
If I bump the curb idle up at all, the ported vacuum starts and affects the vacuum advance which makes everything worse.
Float bowls have all been set just at the bottom of the sight plug hole.
Thankyou in advance to anyone who replies, I’ve been playing around with this on and off for a month or so now, to no avail!
