[FOR SALE] 440-6 pak engine & transmission
DUST UM ALL
new york
Rating - 0%
0   0   0
Its time to let it go i have for sale a 1970 440-6 pak engine for sale it needs rebuild [spun bearing] have original cast iron 6 barrel manifold with original carbs heads were ported polished and have new guides valves and mech rockers installed also have complete bb k frame for a body with original kelsey hayes 4 piston calipers trans is a 727 with reverse manual valve body with TCI 9" 3500 stall covertor ive owned this setup for 35 yrs and its time to go to a new home im going gen 3 hemi im asking 5000.00 for all of it i prefer local pickup it is located in long island ny feel free to ask your questions ill try to answer all i can
Is it an original six pack long block with numbers matching transmission case?
Yes I believe it is I can take some pics of casting #'s if you like, 6 pak is original c/i with original carbs
Can you get the sequence code off the pad please?
Where is the sequence code located I will take a pic of it ,I will be away until 11/27 will do it as soon as I return thanks
Ok where are these codes located that you are asking for will gladly read or take pics thanks
Look on the passenger side of the block, right where the oil pan meets the block. More towards the front, there is a machined pad with numbers stamped into it. On the transmission, there is a machined pad on the passenger side of the bellhousing part. It is visible in your pic....located about 2 o'clock from where the dipstick tube goes into the transmission. Those numbers should match the ones on the motor if they are both out of the same car. There are also numbers stamped on the transmission on the drivers side, on the edge of the case just above the pan. Should be right below where the linkage hooks up. Those numbers will tell the guys interested what it came out of. Hope this helps, and good luck with the sale.
These are #s on block ,tranny & 6 pak hope these help
