dartcuda1
67 Barracuda 500ci 6sp
Big Block 2" Headers
Footnotes Click on number to open footnote
383/400 B-engines
Must use listed cylinder heads to run
the 2" headers on a low-deck block.
Indy 440SR / Indy 440-1 raised-port cylinder heads14, 37, 39, 49
Edelbrock Victor / Stage 6 / Procomp14, 37, 39, 49, 44, 45, 46
440 RB-engines
Fits with the following cylinder heads
Edelbrock Victor / Stage 6 / Procomp cylinder heads13, 14, 37, 39, 40, 49, 44, 46
Front End
Auto TransYES
23, 36, 53
Standard TransYES
53, 55
Floor ShiftYES
23
Column ShiftYES
Push ButtonYES
Power SteeringA-body applications: NO / B&E-body applications: YES
Manual SteeringYES
Air ConditioningYES
StartersListed mini starters10
Using cylinder heads: Edelbrock Victor / Stage 6 Heads
44
Flywheel / Bellhousing10.5" or 11"
10, 28
Steering LinkageOEM only
12, 33
Clutch LinkageOEM only
55
Oil FiltersOEM
Oil PansOEM or Milodon
11
Valve CoversCast Aluminum or Stamped Steel (Stock Height / Width - Width dimensions: 4.065" - 4.300")
58
Coating Options / Header Part No's:Part # TTI440-200C0Part # TTI440-200C1Part # TTI440-200C4Polished Ceramic Coated
with a Thermal Barrier
$896
Footnotes: 17, C5
Part # TTI440-200C5
Serface rust only.$500.00 Plus shipping. Malvern Pa
A body Headers for sale Recommended for 500-750 horsepower
Big Block headers by TTI are constructed of 16 gauge mild steel tubing, mandrel bent on sophisticated computer controlled bending machines for precise fit and uninterrupted exhaust flow. The mandrel bending process maintains a constant inside diameter of the tube for a smoother finish with no restriction of flow and no crimping of the tubes.
- 2" O.D. tubes / merged into 3.5" collectors
- 3/8" thick laser-cut header and collector flanges, contoured for a leak free fit
- Above the steering center link design (under chassis) offers maximum header to ground clearance
- Full length header design for proven power gains
- One piece header tubes / No slip tubes
- Header Sets Include: 1/16" Header & Collector Gaskets, Header Bolts (16pcs) and Reducers/Adapters for hook-up to your Exhaust System.
- Fits Applications:
1967-1976 "A"-bodies
1962-1974 "B"-bodies
1970-1974 "E"-bodies
383/400 B-engines
440 RB-engines
OEM / Indy 440EZ / Edelbrock Performer RPM / Bulldog / Stage 5 / 440-Source
13, 14, 37, 39, 40, 49Front End
Stock or Tubular K-frame
33, 60Auto TransYES
23, 36, 53
Standard TransYES
53, 55
Floor ShiftYES
23
Column ShiftYES
Push ButtonYES
Manual SteeringYES
Air ConditioningYES
44
10, 28
12, 33
55
Oil FiltersOEM
11
58
$896
Footnotes: 17, C5
Part # TTI440-200C5
