Johnnyd$
Member
My stupidity is your gain. I left a little water in my motor last winter and it was enough to crack my block. I'm thus selling the internals plus a bit more. I have a forged crank, eagle h-beam rods, 13.5:1 BRC .030 pistons all balanced. I'm including the gear drove, Crane .543/.561 roller cam, and Crane Roller lifters. Also include Indy 440-2 intake, Indy valley plate, and pushrods that work on a 440-1 head. Just machine a block, use your heads, install new bearings (rings if you want) and you're good to go. ~50 runs on this bottom end. $2500
