o1heavy
1974 dart sport
Swapping the cam on my D300 with a 440. When I put #1 on tdc I found that the distributor rotor was pointing at #6. , but the crank and cam marks lined up, this was during disassembly,so from what I understand I should set the cam to crank timing and then rotate the engine one full rotation and then the drop the distributor in pointing at #1 just trying to clear this up and any advice would be appreciated. ( this is my first big block experience) thanks
