440 cast manifold bolt question
Bmsjax
Layton, UT
For those of you running a BB with cast manifolds what bolts are you using to hold them on? Especially for the long ones you need?
Cant use studs and still be able to take the manifolds on and off. Just had to pull out all the studs to get the manifolds to fit in. Did everyone just bolt them in and then drop in the motor?
