Tur8o Joe
Active Member
Performance Block prep, clean,mag, true deck, line hone, bore 30 over, Torque plate hone, Rotating Assembly: Forged crankshaft, Custom forged pistons, Scat rods Arp bolts and Arp main studs, Hastings moly rings, Balanced Rotating Assembly, Melling high-volume oil pump, Morel Hydraulic lifters comp cam xtreme energy P.N 21-228-4, 545 lift, comps double-roller timing set, * Cylinder Heads: pro comp Aluminum Victor copy bare, performance valve job and Assembly by IMM, 2.20 intake, 1.81 ex, comp springs, ti retainers, comp push rods, Hughes 1.6 offset shaft roller rockers, port matched, NOTE: Motor fully mocked up befor final assembly by IMM engines 10.1 comp. brake in and dyno time only motor makes 502hp and 540lb torque and comes with msd billet distributor, aluminum water pump rpm manifold, CVF Billet Aluminum pulleys and Brackets for PS-AC- ALT-This motor ready to bolt in and rip dont be fooled by other motors on the internet buy this with confidence and pride!! all dyno sheets and docs included PM me if you want to talk any time west coast . will put on pallet for your pic up or shipping $ 9,999.01 this motor cost me $13,200
