gts330hp
Active Member
1972 440 block std crank + .030 bore with trw piston all new bearing bal block mill so the 440 hp is gone. With this short the compression with a 80cc head is 9.78 to 1. Isky cam 480 lift gear drive and arp main stud tap for 1/2 oil pickup. For shipping check with r and l carrer my zip is 54665 400 lbs. With pellet. $2100.00
