Vamisk
The reason im putting this in general discussions is because all i want to know is how low buck i can go with basically swapping the drivetrain.
So im getting $3000 back on taxes. Im wonderingif i can pull it off within that budget.
Here's a list of things i have.
440 block and heads (cost me $350)
727 with the correct tailshaft (free with the 440)
8.75 with a 3.23 open gear
Stock iron intake
B/RB truck manifolds and a drivers side HP manifold
Sum 6400 cam
Correct oil pan
I'd like to take this opportunity to thank yhe mopar community for being so generous to me. The big hurdle was the 8.75. I was about to give up and get a 9 inch when i found one on craigslist for $375 with axles and backing plates up in Mount Pocono.
Heres what i need:
Bbp front dosc brake kit
Bbp rear axles and drums
All of the transmission peripherals
Driveshaft
Wheels
Radiator and fan
Engine mounts
Kickdown linkage
I believe this is it, please let me know if i need, or should get anything else. Foes anyone think this can be done with $3000?
Once again thanks to all the members who have helped me out with cheap parts, you know who you are and are helping me achieve one of my dream cars.
Stock iron intake
Sum 6400 cam
Correct oil pan
Heres what i need:
Driveshaft
Wheels
Radiator and fan
Engine mounts
Kickdown linkage
