440 Parts
hunky
Banned
unknown
Stock parts. Oil pan, Windage tray, Valve springs, Lifters, New & used Main brgs, New hydraulic purple cam, water pump & housing, Rocker arms & shafts, push rods, Head bolts, Rods & pistons. P/steering pump with bracksets and hoses. P/Steering box. Good used manual pitman arm. Crank damper plus other parts. Email any questions. Must have email to send pics. Send email in PM. Steve
Stock parts. 187 Oil pan, Timing cover,Chrome valve covers with breathers,Valve springs, Lifters, New Main brgs, New M/P hydraulic cam # P4286675, water pump & housing, Rocker arms & shafts, push rods, Head bolts, Rods & pistons. New rings installed. Pistons & Rods are reconditioned casting number#1851535. P/steering pump with bracksets and hoses. P/Steering box. Good used manual pitman arm. Crank damper plus other parts. Email any questions. Must have email to send pics. Send email in PM. Steve
Redo
New rods?
No. They are reconditioned as are the pistons. The pistons have new rings also. The size is standard. Steve
hunky, would you check your pms. I sent you one immediately after you posted. Thankya.
