Thenwhat85
built not bought
Hello all. I'm building a 440 with stock stroke, rods(upgraded bolts). And trw dome pistons (2295f .030 over). I purchased a solid roller cam from Hughes. With 1.6 rockers. Total lift is .618 on the intake. I have promaxx heads milled to 75cc (.030 I believe) and the piston are in the hole .050. To get my cam cl correct I need to advance it 4 degrees. Awesome... but intake p2v clearance is only .040 at 10' abdc. I'm running a .020 head gasket and want to keep it for compression (will go to .040 if need be. Question is should the p2v clearance be so close? I've read p2v isn't a huge problem with these motors. And I was talking to another guy with a 440 bigger cam and .000 decked pistons with no problems. Thanks any help is appreciated and sorry about the long post
