hieneken49
Hi, so this isnt for an A body but i figure the pros are all here. I picked up a ramcharger with a 440 BB. The engine is a 1968 440. I had no oil pressure in the engine and a rough idle after buying the truck. I did the oil pump first which didn't fix the issue. I figured it had a spun bearing so i started to tear down the engine to get it rebuilt, when i got to the intake manifold i found a lifter popped out and a bent pushrod.
After some research i found out this could cause no oil pressure, So i ordered a new lifter and pushrod, assembled everything back together and i have some slack in the rocker that had the bent pushrod, see video below.
[ame]http://vid36.photobucket.com/albums/e22/hieneken49/VID_20140824_124009_145-1.mp4[/ame]
What do you guys think, i cant see anything visually wrong with the cam but i did not pull it. Before i continue assembly, is there anything that can be done at this point to shore up that rocker? could the rocker itself be bent?
Jake
Jake
